Clear Engine Ignition Cover Replacement / Repair
Posted: Fri Jul 06, 2018 9:33 pm
The swinging cover over the ignition key broke at the little nub the screw goes into.
Anyone have any luck repairing (5200?) or replacing it?
Strider
Re: Clear Engine Ignition Cover Replacement / Repair
Posted: Fri Jul 06, 2018 11:12 pm
by jng7000
The company that supplied those covers is out of business last I heard. Might be able to find some type of plastic fabricator locally to make a new one or just go to Home Depot and pick up a piece of plexiglass and make a new one. Alternatively you could you grind off the nub and maybe put a hinge on the top? I've thought about doing that to mine thinking it may work better.
Posted: Sat Jul 07, 2018 7:18 am
I purchase some clear Lexan at Home Depot and traced the old one using a scroll saw, then carefully drilled the holes. I masked the edge on the backside and painted the outer edge black, then put on foam with adhesive along the edge. It works great.
Posted: Mon Jul 09, 2018 10:25 pm
Great Ideas, Thanks!
Posted: Fri Apr 23, 2021 9:04 am
by JohnGreifzu
I finally pulled the trigger on this replacement. The Plastic Factory in Bridgeport, CT made it. I chose the tint. Very reasonably priced and great customer service. https://www.theplasticfactoryct.co
Bill's recommendation on painting the outside edge (1/2 inch all around) was great. Much better result than the black vinyl tape used by the factory.
Before and after pics below.
Finished Panel.JPG (34.44 KiB) Viewed 12726 times
Old Panel.JPG (50.88 KiB) Viewed 12737 times
Posted: Fri Apr 23, 2021 9:50 am
John,
Do they have the dimensions to produce this for a "standard" order, or was it a one time custom build?
Posted: Sat Apr 24, 2021 8:27 am
by JohnGreifzu
It was a one-off using my old one as a template. I am happy to give the old one back to them as the mold if this is something we think is worth doing.
Posted: Sun Apr 25, 2021 3:33 pm
Producing More? I would like one!
