reparing wood finish
Posted: Sun Dec 27, 2020 10:04 pm
I have some water stains on my nav station seat and a significant wearing away of the finish on my top stair.
Any advice for renewing the finish?
Sand and apply Epifanes, or does the old faded varnish need to be removed?
Re: reparing wood finish
Posted: Tue Dec 29, 2020 1:47 pm
by Mvallus
Unsure if sanding and refinishing would work on severely water stained areas (deeply dark areas). Minor fades should not be a problem though. Just be very careful to not sand too deep or aggressively on laminated areas (laminates are thin). Refinished my stair(s) last spring (and wood handrails). Epifanes can be tricky, but the results are really nice if you put in the time to sand between coats, clean thoroughly, and properly thin. Definitely use the Rubbed Effect (thinned maybe 10-15%). Removing the pieces to be varnished and taking them home to a more temperature controlled environment helps significantly.
Posted: Wed Dec 30, 2020 11:06 am
That looks so pretty!
I have no dark areas, just light areas
Posted: Wed Dec 30, 2020 11:09 am
Did you use Epifanes Gloss to first build up?
Posted: Wed Dec 30, 2020 11:20 am
rubbed effect only comes as interior gloss, this is ok for wood exposed to the outside often?
Posted: Wed Dec 30, 2020 2:12 pm
Pictures, all advice welcome
Posted: Thu Dec 31, 2020 4:32 pm
I believe the companionway steps are cherry as is the rest of the interior. I would sand carefully and use oxalic acid to remove stains, then rinse with fresh water and let dry completely. Don't use a cheap brush. Get a good quality china bristle brush and comb it out. Start thinning the Epifanes about 20% varnish 80% thinner for a couple of coats so it penetrates the wood and let the initial coats dry thoroughly. Light sand between coats using 400 grit paper, wipe down with thinner and tack cloth between each coat. Then start building up coats increasing the ratio until you are at 80% Epifanes, 20% thinner.
Posted: Sat Jan 02, 2021 12:24 pm
by Mvallus
Yes, I did build-up with a few coats of the gloss (thinned about 20%). I find the interior Epifanes to be just fine for higher traffic areas. If done right, it sets up quite hard and provides a nice protective finish.
Posted: Thu Jan 07, 2021 7:07 pm
Thank you men, I feel I now have a great way forward.
Last Question, do I have to sand everything including the areas underneath the steps that look well, or should it all blend well with some luck?
Posted: Fri Jan 08, 2021 2:10 pm
by TSweather
You will have to sand any surfaces that you want varnish to stick to, though I didn't bother with the underside of the bottom two steps and just taped them off. As for the colors and blending, my re-finished top step came out exactly like Mvallus's above. Pretty sure that the steps on our boat are teak with some cherry glaze stain over them as once I started sanding it smelled exactly like teak and the color got darker. It retained that slightly darker appearance after using the exact same gloss Epiphanes to build up before a final coat of their "rubbed effect" varnish. The color blends fine on the steps as the undersides you never really see in sunlight.
The only place where your color may not blend exactly would be that nav station seat. That I agree with others is a cherry veneer that should blend as long as you don't sand all the way through the thin veneer. Personally I might choose a clear satin finish polyurethane for the nav station seat as long as the cherry retains it's color after sanding. Clear polyurethane tends to add less amber color than Epiphanes does. The true value of varnish is worth it on the steps where they are constantly getting wet, sandy, and walked on, though polyurethane can get a much cleaner finish with less effort for other interior detailing.
Seems like others also took the time to tape off the rubber tread material instead of removing it, which is wise as it was stratospherically expensive at last check. Far more pricey than similar options from Seadek, which I may eventually replace it with.
Posted: Mon Jan 11, 2021 9:26 pm
I removed the tread, need to find the replacement, what product is it?
Posted: Mon Jan 11, 2021 9:35 pm
Lewmar Treadmaster
