Dowel in Lazarette
Posted: Tue Aug 31, 2004 1:14 am
I installed a dowel in the lazarette for hanging lines and fenders on.
Pictures are at:
http://groups.msn.com/J109/lazarettedowel.msnw
I'll post an update soon and let everyone know how useful it is under real world conditions.
Ingredients:
closet rod
closet rod brackets
epoxy
sealant
pencil
saw
drill
screwdriver
rubber band (to hold dowel in place in open-ended bracket)
1. Mark bracket location with pencil.
2. Cut dowel to length (trial & error, length depends on placement, ~54in)
3. Drill holes for closet rod bracket screws (careful, fiberglass on both ends is thin).
4. Put sealant into aft (or both) holes.
5. Put epoxy onto back of brackets.
6. Screw on brackets. I put open bracket astern because there's less overhang.
7. Let dry.
8. Minor gelcoat work because I drilled through
The bolts and fender washers in mine are because I have a wacky plan to use this, the floor panel from the head, duct tape, and spectra line around the flagpole mount as an emergency rudder. I'll let everyone know how that works after trying it.
Eric
[Posted by: Eric]
Pictures are at:
Ingredients:
closet rod
closet rod brackets
epoxy
sealant
pencil
saw
drill
screwdriver
7. Let dry.
Eric
[Posted by: Eric]
