Check the tabbing on your galley
Posted: Fri Mar 10, 2023 7:02 pm
I found the tabbing between the galley and hull had come delaminated. Today I decided to address the problem. I used a Fein multitool and cut the tabbing flat on both sides, then sanded the surfaces. On another day when it is warmer, I will tab it again with 17oz biaxial cloth and once it kicks will paint with white gelcoat.
The root cause is insufficient resin infusion in the glass. The tabbing separated from the hull and the glass strands were dry. Additionally it appears that the tabbing was attached to the cabinet work over polyurethane so did not have a good surface for bonding. I made sure to sand the polyurethane off so the epoxy will bond on the new tabbing.
Forward of Galley
Under Stove before removing tabbing
Under Stove after removing tabbing
Forward of Galley
