long delay before water exhausts
There seems to be a long delay only recently from the time the engine starts, to water appearing at the exhaust. As much as 45 seconds. Does this indicate a problem?
Re: long delay before water exhausts
yes! Check the following:
- Air coming in hose connections on raw water suction side from sail drive, strainer and raw water pump
- Bad impeller / missing vanes on raw water pump
- air leak on raw water pump casing / o-ring
- air leak on strainer cap / o-ring
- belt slipping on raw water pump
Wow, that was simple. Air leak on the strainer.
Thank you!
Thank you!
To close the thread, the problem turned out to be a loose v-belt between the pump and engine.
