Intermittent water intake
Posted: Thu Mar 13, 2025 1:38 am
I have a mystery I haven’t been able to solve. Two years ago after the first leg of a 2-day distance race, After we docked I noticed I had about 2 gallons of water in the starboard quarter-berth “the garage”. I cleaned it out, and the next day, no issue. Over the past two years, I will intermittently get water in the garage. It seems not to occur in lighter winds and calmer conditions, but when out in moderate winds (≈ 15 kts), sometimes there is water, and in other races, there isn’t. The extreme came this past weekend. The garage was dry when we started. Started downwind in about 15-20 kts, but at the rounding mark 13 miles away, the winds were > 30 kts. We had 3-4 ft waves, the crew stacked more toward the back, and the waves/waterline was just at deck level at the stern for the downwind leg. Once we docked, I inspected the garage, and I had 4 gallons of water back in the quarter-berth, the most ever. Almost to the point it was at the head door threshold, nowhere to drain. When I went to inspect the rudder post, gator, and the inside of the stern section, I could not see an obvious source for the water.
She was hauled out in January 2024 for new bottom paint, and I had them drop the rudder and inspect/clean the rudder bearings, and all was fine (so they said). I do have a gator on the post, and it appears fine and clamps retightened. The two stern access plates (circular rudder one and the larger rectangle) were resealed.
I’ve inspected the area around the exhaust thruhull, and it appears fine. I don’t see any obvious separation, crack of the hull/deck interface at the stern (maybe there is one when the boat flexes?). I suspect somehow it is interrelated to the waterline, rudder, rudder bearings, and gator. My guess is that in heavier air or more weight in the stern, the water line rises and impacts the rudder and bearing/gator, and there is a leak somewhere when the stern is pushed down.
So looking for any ideas on where to start. I’m thinking about color dyes in different areas in the stern to see if the water is from one section, maybe adding weather stripping around the rudder post where the gator is clamped to it. I thought about putting a camera down there, or even a rookie crew member with a flashlight (just kidding, but I’m desperate). But first it would be nice to definitively know where the water is coming from.
On a final note- does anyone see a problem with putting in a drain hole at floor level next to the head door into the engine bilge area? So, if you do get water in the garage it at least has a place to drain. Is there a reason they didn’t put a drain in that section? On the extreme it can accumulate a lot of water and would only start to drain once it reached the head door threshold. Design flaw?
Any ideas?
Thanks for any insight.
Jerry Woodfield
S/V Shada
J/109 #44
Seattle, WA
Any ideas?
Jerry Woodfield
S/V Shada
J/109 #44
Seattle, WA
