Sold: Ursa, Hull #203 - Located Fall River, MA
bmastror
Post by bmastror »
2005 J/109 Ursa, Hull #203 - Located Fall River, MA
US$135,000
Photos can be found at https://www.yachtworld.com/yacht/2005-j ... -10235021/
Please contact Tim Kohl at 203-233-9709
Sail Inventory
Racing Sails
• 2017 North 3Di mainsail
• 2014 North 3DL mainsail
• 2016 North 3Di 105% jib
• 2015 North 3DL 105% jib
• 2024 Quantum spinnaker (blue)
• 2018 North spinnaker (white)
• 2012 Quantum spinnaker (red/white/blue)
• Code 0 with furler
Cruising Sails
• UK Sailmakers mainsail with Dutchman system with additional mainsail cover
Engine
• Yanmar 3YM30 diesel engine (29 HP)
• Yanmar SD20 saildrive
• Heat exchanger removed, cleaned, serviced, and reinstalled as well as overall engine serviced (2024)
• Saildrive serviced and inspected regularly
• No signs of water intrusion noted during 2025 saildrive inspection
• Saildrive zincs replaced annually
• Alternator belt replaced (2026)
• Total engine hours unknown due to replacement of the engine-hour meter. Approximately 1,300 hours since 2010. Engine has been professionally maintained and is in regular use.
Electronics
• B&G Zeus³ 7" GPS/Radar display at helm (2022)
• B&G Triton2 S/D/W Wired Wind Package with 2 Displays and B&G Vulcan 5" on spray hood
• 2020 B&G radar
• Raymarine GPS/radar at navigation station
• Raymarine ST6001 autopilot
• AIS (receive and send)
• Icom VHF radio
• Tacktick - mast mounted
• Removable speed wheel with blanking plug
Electrical
• 12V DC electrical system
• 120V AC shore power
• Three Odyssey ODX-AGM31M AGM batteries (2024)
• Victron BMV-712 battery monitor (2024)
• New Balmar MC-618 regulator and Balmar SG-200 battery monitoring system installed (2023)
• Xantrex PROwatt SW 1000 Power Inverter (2020)
• Upgraded alternator
• New battery charger (2026)
• New SmartPlug shore power cord (2026)
Equipment Included
• Custom Fairclough winter cover
• Dodger
• Removable dock box
• Tides Marine SailTrack system
• Wheel and mainsail cover
• Anchor roller
• EPIRB
• LifeSling and horseshoe buoy
• Fenders and dock line
Maintenance & Upgrades
Rigging / Deck
• S1 and S2 spreader bars upgraded, and rod rigging components serviced by Newport Rigging Group (2025)
• Standing rigging replaced (2011)
• 2019 epoxy isolation of all deck hardware penetrations including chainplates and stanchion bases (pictures can be provided)
• New lifelines (2024)
• New sheaves in mast replaced (2024)
• New sheaves in boom replaced (2020)
Running Rigging
• New spinnaker halyard (2026)
• New main halyard (2023)
• New jib halyard and jib sheets (2022)
Hull / Steering
• No known wet-core issues
• 2024 upper and lower rudder bearings replaced
• 2024 bottom professionally stripped/prepped and converted to SeaHawk BioCop TF
• 2026 fresh bottom paint (2 coats
Mechanical / Plumbing
• Bilge system serviced with new Rule 1100 GPH bilge pump and Ultra Safety float switch (2019)
• Two new Plastimo 39-gallon flexible water tanks (2020)
• Head hoses and joker valve replaced (2022)
Safety
Two new Amerex fire extinguishers (2023)
sailrmann
Re: For Sale: Ursa, Hull #203 - Located Fall River, MA
Post by sailrmann »
Why does your boat stern say San Francisco but you're in Massachusetts? How long have you owned her?
bmastror
Post by bmastror »
The original owner had her in San Francisco and brought her to the East Coast when he moved to New England. I’m the second owner and have had her for almost 16 years. She’s USCG documented, and I never bothered changing the San Francisco hailing port. Plus, it’s always been a great conversation starter!
sailrmann
Post by sailrmann »
She's a great looking boat! Well cared for.
