Stanchion Swap?
Posted: Fri Jan 01, 2016 12:01 pm
by J-109 Emoticon
It is my understanding that European built and US built 109's have a different stanchion configuration at the gates (see attached pictures). My question is would swapping the stanchions be permitted under class rules?
- J109-EU Stanchions.jpeg (156.41 KiB) Viewed 33537 times
- J-109 US Stanchions.jpeg (23.96 KiB) Viewed 33537 times
Re: Stanchion Swap?
Posted: Mon Jan 04, 2016 12:03 pm
Obviously the class measurer has the final say, but I believe that this is allowed by the following class rule
1.2 J/109’s which comply with these Rules shall be built only by builders licensed by J/Boats, Inc. and shall comply with specifications determined by J/Boats, Inc. Repairs and modifications shall be made in accordance with J/Boats, Inc. specifications.
There are various specs and drawings used throughout the production cycle of the boat. What you are requesting is consistent with different vendors using parts that may be more easily available to the production facility in France or the US. Examples of this are the engine (Volvo or Yanmar), Hatches, water tanks, etc. If a part is specified on a production print licensed by J/Boats and used in the build, it should be allowable if you want to swap it out.
That being said - I kind of like the US version of the stanchion at the gates, as there is no tripping hazard when the gate is closed.
Re: Stanchion Swap?
Posted: Tue Mar 22, 2016 3:45 pm
by J-109 Emoticon
So I while I'm trying to procure the EU stanchions I wanted to run this by the forum. Would the class frown upon simply replacing the gate stanchions with the standard vertical peice and plugging the gate support with a washer and through bolt. See picture. Thoughts?
- Replaced gate stanchion
- image.jpeg (655.99 KiB) Viewed 33098 times
Re: Stanchion Swap?
Posted: Thu Jun 30, 2016 7:54 am
by Rosalita#73
Both European and US designed stations are allowed per the class rules. Switching from one style to another is permitted. The size, height and weight must be equivalent. Any modifications that are outside of the 2 designs are not permitted.
Rick Hanson
J109 Class Measurer
Re: Stanchion Swap?
Posted: Sat Apr 29, 2023 1:55 pm
Are new stanchions posts available, with or without the base, for sale somewhere for U.S. built 109's boats?
Re: Stanchion Swap?
Posted: Sat Apr 29, 2023 3:17 pm
Yes - Whitewater Marine per the Equipment Suppliers Page. Mouse over Market and click on Equipment Suppliers.
