Zinc Hungry J109
Posted: Tue May 02, 2017 8:09 am
Hello, I am the new owner of Strider
The previous owner kept her in good shape, but she does come with a corrosion problem. I have a rather good comprehension of electrics and electronics (I use to write for Panbo, Sail Magazine, and Practical Sailor). Maybe one of you can call out something I should be checking for specific to J109's?
The problem presents as consuming 2-3 Zinc's a year, being rarely connected to Shore Power. In addition, a Yanmar sail-drive replaced in 2004 has been ravaged, with a hole on the side 1/3 up from the bottom appearing while commissioning her and grooves as deep as 8mm around the top of where the sail drive enters the bottom.
The owner said she came from a dock which was known for this kind of problem, and kept the shore power disconnected. Have any of you experienced a J109 being that sensitive to nearby boats?
The only thing I find odd, is that there are two galvanic isolators. The standard one behind the AC panel and a Zinc Saver mounted a few feet forward of the AC outlet.
Strider #332
Strider #332
