Propane Tank wont fill
Post by Dan Corcoran » Sun Aug 27, 2017 7:07 pm
My first time filling propane tank, the filling station cannot get propane to go in the normal nozzle.
Is there a trick? What is that extra large connector on the tank for, does the propane go in there?
j30_rhapsody
Re: Propane Tank wont fill
Post by j30_rhapsody » Sun Aug 27, 2017 9:10 pm
Probably a broken stem or seat on the valve. It fills like any other propane tank through the outlet where the regulator attaches.
Post by Dan Corcoran » Mon Aug 28, 2017 5:03 pm
Does this then require a new tank, or is the valve replaceable?
Is there a good source for tanks already setup to mount in J109's?
neilhazel
Post by neilhazel » Tue Aug 29, 2017 8:12 am
A research based approach Lose face Fat and Duoble Chin. Chek Lose hips and thighs fat and other Fitness Realted Tips. We Working Related Research Work.
Post by Dan Corcoran » Tue Sep 05, 2017 3:34 pm
Float seems ok, I can here it moving inside at the angle expected moving the tank
As a temporary workaround, I found someone who can fill the tank through the additional connection on the tank
cercole
Post by cercole » Fri Sep 08, 2017 11:06 am
I ran into this two years ago. I believe the tank needs to be filled while on its side like when mounted in the locker.
Post by Dan Corcoran » Mon Sep 11, 2017 4:39 pm
Didn't think of that! Anyone sure?
