Clear Engine Ignition Cover Replacement / Repair
Post by Dan Corcoran » Fri Jul 06, 2018 9:33 pm
The swinging cover over the ignition key broke at the little nub the screw goes into.
Anyone have any luck repairing (5200?) or replacing it?
Strider
jng7000
Re: Clear Engine Ignition Cover Replacement / Repair
Post by jng7000 » Fri Jul 06, 2018 11:12 pm
The company that supplied those covers is out of business last I heard. Might be able to find some type of plastic fabricator locally to make a new one or just go to Home Depot and pick up a piece of plexiglass and make a new one. Alternatively you could you grind off the nub and maybe put a hinge on the top? I've thought about doing that to mine thinking it may work better.
"Junkyard Dog" #168
Post by Vento Solare » Sat Jul 07, 2018 7:18 am
I purchase some clear Lexan at Home Depot and traced the old one using a scroll saw, then carefully drilled the holes. I masked the edge on the backside and painted the outer edge black, then put on foam with adhesive along the edge. It works great.
Post by Dan Corcoran » Mon Jul 09, 2018 10:25 pm
Great Ideas, Thanks!
