Wood finish blushing
jng7000
Post by jng7000 » Sun Jul 08, 2018 5:44 pm
Has anyone refinished the wood interior and had good results? Anyone else have a problem with blushing/milky white discoloration from seemingly minor exposure to water or humidity on the wood finish of the bulkheads, nav station, etc? We keep a dehumidifier on the boat running all the time when we're not on there and California has fairly dry air as well so not sure why it blushes so easily. Sometimes we'll get the blushing on the bulkhead even if just a wet shirt is laying against it for only a short time.
Second question, and this is sure to spark plenty of debate, what's the best thing to refinish it with? I'm guessing an indoor/outdoor polyurethane would be best like a minwax helmsman or varnish like an epifanes? Poly's are just such a pain, especially oil based. Such a long time between re-coats, hard to fix mistakes or touch up and the odor takes a really long time to dissipate. I'm wondering if an oil based lacquer or maybe even a water based poly would be sufficient? It is after all technically an interior application even though it will come in contact with some water/wet clothes occasionally.
"Junkyard Dog" #168
jng7000
Re: Wood finish blushing
Post by jng7000 » Sun Jul 08, 2018 6:22 pm
Going to reply/add to my own post. Unfortunately this is not the only time I've been known to have complete conversations with myself :D
Anyone have experience with Petit SeaGold? Sounds like a miracle product, at least according to the manufacturer. Water clean up, low/no odor, no sanding between coats and quick re-coat time. Sounds too good to believe. I'm always a bit leery with water soluble products when looking for something water resistant. Link to the SeaGold page if you're interested: http://www.pettitpaint.com/products/var ... h/seagold/
"Junkyard Dog" #168
