VIENTO is one of the cleanest and best maintained J/109’s available. She is comprehensively equipped with updates to her sail inventory (North 3Di), running rigging, canvas, and electronics. Her low hour Yanmar 3YM30 engine runs perfectly! VIENTO has been primarily day sailed and only VERY lightly raced making her a beautiful J/109 example. See below for additional information
Asking $149,000.
Please Contact Mike Farthing
Phone/Text: 503-757-0358
email: mkfarthing@comcast.net
EQUIPMENT LIST AND UPGRADES
Boat Name, Hull Number, Year Built
J/109 Viento, US built #254, 2005
Standard 7’-0” Keel
Engine
Engine Brand: Yanmar
Engine Model: 3YM30
Engine Hours: 652 hours
• Balmar serpentine belt and pulley system - reduces vibration, belt wear, improves alternator function, 2017
• Raw water pump, 2017
• Engine spares including fuel filter, belts, raw water impeller
Electrical System and Electronics
Shore Power System 30amp 120V with Pro Marine 30 amp galvanic isolator
• 50’ Marinco eel shore power cord, 2017
12V Electrical System
• (2) Lifeline AGM 105 Amp hour house batteries - 210 total amp hours, 2017
• Lifeline AGM 105 Amp hour starter battery, 2017
• Xantrex HF Inverter Charger - modified sine wave inverter charger, 2017
Notes:
a) House and starter batteries utilize Blue Seas Automatic Charge Relay System (ARC) the house and starter batteries are isolated from one another to protect the starter battery from being overly discharged but can be combined if needed, 2017
b) Batteries utilize temperature compensated charging incorporated with the original high output Balmar alternator and regulator system. This system has been accurately set to meet the requirements of the Lifeline AGM batteries, 2017
Electronics
• Raymarine ST60 instrument system with (4) displays at the sea hood including wind, speed, depth and a Multi Function Display (MFD)
• Raymarine C80 MFD chart plotter
• AIS - Digital Yachts iAIS system with wireless router, integrated with the C80 MFD, works well with iNAVX software and Apple iOS devices, 2017
• Standard Horizon GX1700 fixed mount VHF radio with GPS and DCS, 2018
• Standard Horizon HX870 hand held VHF radio with GPS and DCS, 2018
• Raymarine ST6002 autopilot controller and linear drive autopilot system
• Raymarine S100 wireless autopilot controller, 2017
• Clarion AM/FM radio with 2 interior and 2 exterior speakers; the exterior speakers are mounted behind waterproof deck plates, 2018
Sails and Running Rigging
Sails
• North 3Di Endurance Class OD Main, 2017
• North 3Di Endurance Class OD 105% Roller Furling Jib, 2017
• North 3DL PHRF Main, 2007
• North 3DL PHRF 155% Jib, 2007
• North Class OD 108 sq mtr Spinnaker, 2006
Note the above 5 sails are in very good to excellent condition
Sails (continued)
• North Full Batten Radial Dacron Main, 2006
• North Roller Furling Radial Dacron Jib, 2006
Note the above 2 sails were recently serviced but are old and used as winter sails
• North Spinnaker Snuffer system
Running Rigging
• All running rigging except the Main Sheet and Reefing Lines have been updated within the last 2 years. All new lines are Samson MLX, Samson Amsteel, or New England Endura Braid.
Canvas
• Wheel cover
• Main Sail cover
• Winch covers x4, 2017
• Lifeline covers x6, 2017
• Dodger
• Dodger cover, 2017
• Spinnaker sprit/pole cover, 2017
• Mast boot cover, 2017
• Cockpit cushions x2, 2017
• Cockpit Line Bags with integral drink holders x2, 2017
• Jib Sock, 2017
• Hatch cover, 2017
Ground Tackle and Docking
• 22lb galvanized delta anchor with 12’ galvanized chain and 250’ of rode
• Taylor Made Bumpers x2
• Double braid dock lines x4
Additional Equipment and Updates
• Steering wheel has new powder coating and new leather wrap, 2017
• Starboard 39.6 gal fresh water bladder replaced 2018
• Potable water filtration system with Pentek Microgard Filter, 2018
• Hot and cold pressurized water system
• Hot and cold stern wash down shower
• B-1 Fire Extinguishers x3
• Custom Jack Lines
• Life Sling System
• Original Owners, electronic, and equipment manuals
Sold: 2005, VIENTO, Hull 254, Portland OR
- IMG_2725.jpg (736.46 KiB) Viewed 6628 times
- IMG_2036.JPG (546.26 KiB) Viewed 6629 times
Mike Farthing
Hull 254
PDX, OR
Hull 254
PDX, OR
