Lithium Ion Batteries
Posted: Thu Jan 02, 2020 4:51 pm
The industry is getting closer to providing affordable lithium-ion battery replacement for lead-acid batteries, these batteries are currently excluded by the J/109 class rules.
It could be helpful to have an alteration of the rules to allow such batteries in 2023 or later, so owners can plan in advance as lead-acid batteries have 4-10 year lifetimes.
I open this thread to start a discussion that can continue through 2020 if anyone is interested.
I am not in the market for such batteries, but as an electronics evaluator/marine electronics editor for practical sailor magazine, I may become interested in testing these batteries on my J/109 in 2021 or later.
For others in our class, there could be an interest in having much more power available for cruising or the desire to make their boats even more environmentally friendly by eliminating the diesel engine altogether. as at least one J/121 has done
Link: https://oceanvolt.com/testimonials/elec ... oats-j121/
Some initial thoughts:
(1) Two approaches
- Increase the minimum amount of Ahr for boats with Lithium-Ion. E.g. Required Ahr = Ahr of Lead Acid + 1/2 * Lithium Ion Battery capacity.
- Swap the current minimum of Amp Hrs with a minimum weight of battery plus battery management system (BMS) and other stuff needed to make lithium batteries safe and effective to use on a 109.
(2) Weight issues - Ideally the rules would be neutral to the user's selection of solutions to deal with lithium challenges.
- The rule could perhaps allow additional safety components to be counted in the weight.
- Some batteries have an internal BMS, while other designs put the BMS and components like relays external. The rule should not favor one approach over the other.
- BMS's have protection systems that can cut-out all the power on the boat without warning. Some owners may want to keep a mix of lead-acid and lithium while others may choose to have two lithium-ion batteries.
- Potentially our alternators will not be up to the task of charging some types of batteries and need to be replaced.
- Potentially our shore chargers will not be up to the task of charging some types of batteries (for example charging a mix of lithium and standard lead-acid batteries may be somewhat restricted, as our current shore charger requires you select the same battery type and voltages for both battery banks of batteries.
- Diesel replacement. Potentially there would be no diesel engine, the owner could opt for a massive battery bank and electric motor. Perhaps then the owners choice of engine is added into the weight equation.
- Allow owners to make up for a deficiency in achieving weight minimums, with a bolted in weight in their battery compartment.
(1) Two approaches
