What gel coat color for J/109s from 2007?
Post by Dan Corcoran » Thu Mar 26, 2020 11:20 pm
Where to find matching gel coat color for J/109 2007? I see Spectrum has gel coat for J-Boast but they stop at year 2004.
https://spectrumcolor-com.3dcartstores. ... %2FIuKm9fP
Re: What gel coat color for J/109s from 2007?
Post by Vento Solare » Fri Mar 27, 2020 5:58 am
A good fiberglass repair guy can mix a batch to match well. The white on my 2005 hull #266 uses this.
https://minicraft.com/store/Piranha-Gel-Coat-p138783796
It is the same that was used on Ted Herlihy's hull 72 since the guy who filled cosmetic scratches & dings on my boat used the same can.
If you email Mini-craft they may be able to tell you the color you are trying to match.
