M-19 Water pump belt replacement
Has anyone found a cogged/notched version of the M-19 water pump belt?
Re: M-19 Water pump belt replacement
Is your belt slipping or creating black dust? The regular belt seems to work fine for me. If dust is created, take a straight edge and check that the pulleys are in line. If not, you need to fix that.
