Lithium batteries for J/109 class
Hi. I am Dan Corcoran, a fellow J/109 owner, and a part-time marine electronics writer for practical sailor magazine. In addition, I own a software startup, focused on helping hospitals achieve the highest level of safety and quality (www.SafeQual.net).
Shortly after the J/109 Class Annual meeting the Class Measurer, Bengt Johansson, contacted me to discuss the most recent developments of lithium-ion battery technology, asking if this technology is suitable and ready for future use in the J/109.
He suggested I post a summary of what we are watching for, and the effort to develop new class rules for Lithium. I hear that such a new rule would be no sooner than 11 ½ months from now (e.g. Annual October 2022 meeting).
Are you excited about using lithium for weight savings? Don’t be! If you are thinking of replacing your lead-acid batteries with lithium only to save weight, don’t rejoice just yet. Our 2002 designed boats are not great candidates for these batteries if you are already configured at the class minimum of 150Ahr. With just 150Ahr, the weight savings when safely replacing lead acid with lithium could be negligible.
Instead, you can gain a lot more capacity for the same weight, useful for running your engine less frequently like in a distance race, but I am not writing here to promote this technology, rather share safety issues that concern me if shortcuts are taken in the conversion process.
I recently answered the question, “if lithium batteries are ⅓ the weight of lead-acid, how can you say no weight savings on a J/109.”. Can't we save 50 lbs?
This is the short version of the answer ...
Our boats are not designed for these batteries, neither I suspect are the latest J-boats. If they were so designed, they would have separate 12-volt charging vs. load buses (for safety reasons). Not only don’t our boats do this, but they also share the same red battery cable for (i) starting the boat, (ii) charging the batteries from the alternator, and (iii) providing a battery voltage sense lead to our Balmar regulators, a clear wiring shortcut. (Hint: Fix (iii) with a dedicated 10 gauge wire, and your batteries will charge from the engine faster)
Retrofitting our boats for lithium involves many wiring changes and the incorporation of circuitry to protect the batteries, alternators, and other electronics.
“Drop-In” lithium batteries are advertised as eliminating the need for extensive retrofits, enabling the owner to directly swap out lead-acid batteries one for one. I strongly don't recommend this.
To accomplish this feat the safety mechanisms that would be part of a standard Lithium retrofit, such as battery monitoring, high interrupt capacity fuses, and remote-controlled battery disconnects, are built into the batteries themselves so that the red and black cables to your lead-acid batteries simply connect instead to the drop-in lithium battery.
Lithium batteries don't like many things. They don't like to be discharged fully, they like even less to be charged when they are already very low, they don't like to be charged when they are cold, etc. Like sealed lead-acid batteries, they don't like to be overcharged or short-circuited either. Internal lithium battery monitors also don't like electrical storms that produce EMP pulses, something that lead-acid batteries tolerate very well.
The safety mechanisms in the battery will disconnect the internal lithium batteries from your electrical system if they sense any of the conditions that could cause damage to the batteries. And that’s the rub. That disconnection at best will leave you or your delivery crew without house power until a reset button is pressed. If the reset does not work you have only a starter battery that has silently deteriorated if your charging system isn't wired for two chemistries. If your engine was running at the time of disconnect, your boat's electronics and alternator can be destroyed as the power from your alternator, having nowhere to go, turns into a high voltage spike. In addition to the familiar alternator diode frying issue that happens if someone operates the battery switch while the alternator is running, boat system electronics are fried as well. Then your starter battery is useless, having nothing to power. No ship VHF, nav lights, smartphone chargers, etc. All gone.
At least we have sails. I can't imagine what a clueless powerboater would do. Hopefully, they at least have a towboat contact so it doesn’t become a salvage dispute when they fire off their flares.
In addition to the key challenge of drop-in batteries suddenly disconnecting power to protect the batteries, they are also less idiot-proof, placing demands on you and your crew to know more about your electrical system. For example, assuming the disconnect happened while the engine is off, does the delivery crew know this is the scenario to select the "both" position on the battery switch, the position you possibly labeled "NO".
The opposite of idiot-proof, this is complicated stuff. For example, if you have a lead-acid battery and a lithium battery on your boat, you have to modify your charging to treat each battery differently and be careful not to use the BOTH setting on your battery switch. Using BOTH with the alternator running will silently cook and reduce the capacity of your starting battery, using your stock J/109 shore charger will damage one battery or the other.
Even with TPPL batteries, there are ways to wire your starter battery where the battery is drained by about 1+ Ahr every hour, while the engine is charging your house battery. After 18-hours of motoring, your starter battery may not be able to start your engine next time you need it.
The solution to these challenges lies in a mixture of having two drop-in lithium batteries, instead of one, some additional wiring and protection devices in case both lithiums fail at the same time, protecting your starter battery from mixed chemistries with a smart lead-acid trickle charger, having chosen lithium batteries with remote control panels, and supplemental alarming so you know if a lithium battery has disconnected, leaving you with just one.
Some wiring scenarios will require your lithium battery has 3 connections, a ground, +12v load, and +12v charging. Many lithium batteries come with only two.
Once done safely the weight savings compared to 105 Ahr house and 50 Ahr starter battery may be none, but you will have weight savings if today you race with 2 or 3 105 Ahr batteries. If done right, you could have more idiot-proofing then a stock J/109 electrical system, and a whole lot more usable battery capacity than 2x 105 Ahr, for activities like distance racing and cruising.
Until that day where we have class rules in support of lithium batteries, try to hold back your enthusiasm and avoid drop-in lithium. They are not class legal, not safe enough for you and your crew, and they place the alternator and electrical systems of your boat at risk of destruction.
The batteries may also not be compatible with our future class rules and may not be ABYC marine standards-compliant, an issue if you sell your boat.
It is my intent to design an upgrade to my boat, probably before I help the effort for the new class rule. When I do so, I will be sure to write again and share how to do it safely either to the class or in Practical Sailor magazine. Until then check out the latest December 2021 issue where I write about the Furuno SX200 compass.
Sail Safe, and if you are in the healthcare or investment industry, ask me about my startup SafeQual. I can be reached through Gmail at 516captain.
J/109 Class | Owner #332 Strider
practical sailor magazine | marine electronics contributor
Re: Lithium batteries for J/109 class
All I can say is wow Dan. This is one of the most comprehensive reviews I have ever seen about Lithium battery conversion issues. Excellent work!
Thanks Dan!
A very good summary of the issues we face approving Lithum Ion batteries. From a Class rule point of view the perceived weight savings may be the main issue, we do not want to get into an arms race spending three times as much to potentially save 80 - 90 # and on top of that have severe safety issues.
For all to know, the reason to start this discussion now is to collect enough information for the TC to make a decision if we want to propose a rule change in time for the annual meeting October 2022.
To be clear, Lithium Ion batteries are not approved for the 2022 season.
carlbraden
Great information Dan - many thanks for sharing - look forward to whether these idiot proof lithium drop in batteries in the future can improve and address the risks and issues you identified.
I am interested in knowing if we have any experienced electrical installers in the class, and if so:
- how would you alarm two lithium batteries, to indicate to the owner one in alarm?
- what drop-in lithium batteries are gaining popularity where you are located?
Also interested in which owners have upgraded from their
1. Balmar Smart Regulator, MC-614. Which product did you choose?
2. Shore charger. Which product and model did you choose?
3. Link 20. Which product did you choose?
(I use the Balmar SG200)
4. Choose a small starter battery, how small did you go, what worked for you?
(I use the Odyssey TPPL PC925L, 28Ahr. Note because the charging voltages are different, my house battery is also an Odyssey TPPL, the PC2250)
Writing to update everyone on the first post in this article. Marine electrical ABYC Standards for Lithium Batteries on boats in the US won't be out until July 2022. It may be optimistic that I have something to offer up for the class rules this year. We may need to wait for new battery products that follow, as potentially none of the drop-in battery products will meet this requirement:
ABYC TE-13 13.5.6 If a shutdown condition is approaching, a BMS (battery management system) should notify the operator with a visual and/or audible alarm prior to disconnecting the battery from the DC system. (Note The ISO/European standard requires the visual/audible alarm is "Clearly perceptible from the main helm position, prior to disconnecting the battery from the DC system", and could potentially work its way into the ABYC requirements before they become final in July 2022.
Why is that a proposed standard for Lithium batteries and not lead-acid you might ask? That's because Lithium batteries have protection circuity built into them, that ultimately requires all the electric current to pass through a bank of semiconductor electronics that is programmed to shut off under various conditions like low voltage, high temperature, etc. They can also be prompted to shut off from a nearby electrical discharge, When this happens the boat operator may be surprised, better that they are alerted before or at least during the power outage as to the cause. Not an issue with lead-acid batteries, even if lightning strikes the boat directly, the battery will keep on going unless damaged.
Many drop-in lithium batteries have an alarm built into the battery to sound or light after they shut down the power. That will be hard to hear / muffled on a J/109. Some drop-ins don't have a provision for a remote alarm. As far as I know, none will alarm after a lightning strike nearby, but you could instead rig up a bilge alarm style circuit with a small battery if you have some skills.
Before I go on. REMINDER, LITHIUM BATTERIES ARE NOT CLASS LEGAL. When you are done reversing the change to be class legal, e.g. replacing the lithium batteries with lead-acid to be legal for any given race, you will have increased the weight of your boat with all the extra cabling, etc. while sailing with lead-acid.
Undoubtedly someone here isn't going to wait. If that will be you, I suggest you first take a peek at the articles below. Having this information will inform you of either converting your current installation into something safer or purchasing for a new install when you are not racing.
If you are interested in Lithium for weight savings, just stop now. As I wrote in the first article, a safe installation let alone an ABYC standards installation is achievable on a J/109 with weight savings vs. the weight of a 150 Ahr minimum class legal lead-acid install. The only reason to consider lithium is if you "need" to power your boat without starting the engine for much longer periods of time, or want to add conveniences like a microwave oven, air conditioner, or inverter capable of running a hairdryer or something.
If that is you, you need more power (not weight savings), great articles here about issues I will encounter helping to create a recommended install, that could inform your decisions as well:
Drop-in batteries:
https://marinehowto.com/drop-in-lifepo4 ... -consumer/
Make your own: (read above first)
https://marinehowto.com/lifepo4-batteries-on-boats/
When I do get to that recommended configuration, I will be looking for something along the lines of the drop-in batteries article as the make you own approach is just too much work, and the Mastervolt (not drop-in, Lithium Ion) won't fit in our 109's (batteries are too tall)
Cheers
Drop-in batteries:
Cheers
Another perspective, written with some humor, on things to consider in an install. Some of this adds more weight
https://loosecannon.substack.com/p/your ... oDkRkqUo3c
Making progress on this. Is there a J/109 owner, that does not do class racing, implimenting Lithium that would be interested in collaborating?
As I cannot make the changes to my own boat without causing a rule violation, and frankly don't see a weight benefit in a safe design even if I could, I would be interested in collaborating with someone who can.
traci15Ren
This is interesting information
I will be replacing an AGM Group 31 house battery in the spring. I was looking at the various AGM batteries and noticed the specified performance of the Firefly battery looks very good.
See page 4 of the Firefly Oasis MCF-G31 Sec sheet
Compare with a typical battery from North Star NSB-AGM31
Unlike a Lithium battery, the Firefly does not require a battery management system or changes to the charging system. The life looks better and there is a more consistent plate surface temperature with the carbon. The Firefly is 74 lbs compared to the Northstar 75 lbs so there is no appreciable weight difference.
Questions
Questions
- Anyone have real world experience using the Firefly batteries?
- For the class measurer - will the Firefly battery meet the intention of the class rules for a drop in replacement?
I read a review a year or two back on practical sailor magazine I think that compared Firefly, Odyseey, and I think one other advanced AGM battery. The author wrote that over a short period of time the Firefly and its competitors lose their fast charging capability and need some love to get it back, and are otherwise finiky. That, and other, characteristics has me wondering if the Odyssey Extreme (which I use) are more similar than different.
One of the things I like about the Odyseey if they offer different size batteries. I use one of the largest batteries as my house battery (126 Ahr is it?), and then the smaller battery intended for motorcycles (28 Ahr?), for my starter battery. Together I achieved the required 150 Ahr minimum at a big weight savings over having a larger starter battery. One of the reasons the starter battery can be so small, is that the TPPL chemistry allows the battery to perform well in either house or starter battery role.
Some things I had to take into consideration.
(1) These specialized lead acid batteries work at different voltages than standard lead acid. You need to slightly increase the float voltage or the battery can quickly lose its maximum storage capability. Our default chargers can be configured this way, but also measure the voltage that actually arrives at the battery during float charge to make sure it is in the middle to high end of the recommended float charge voltage. I found that the 109 chargers displayed voltage was not as high as what arrived at the battery.
(2) No battery likes to be overcharged, making your starter battery smaller makes the problem worse. Leaving the power switch on "both" is really bad no matter what battery chemistry you use. I needed to isolate my starter battery from the alternator output. That in turn meant that while engine was running, the house battery received power while the starter battery drained at a rate of 1 AHr per hour. On a small battery, running your engine for say 18 hours is enough to make a 28Ahr battery unable to start the engine. The solution was to (i) run an additional wire from the battery switches to the engine compartment so that the alternator output and the engine starter didn't share the same red wire. (ii) install a DC to DC charger between the house battery and the starter battery, to honor the starter battery's correct charging profile and keep it from draining while the engine is running. (iii) run a lead from the engine start switch to the DC to DC charger so that it turns on only when the key is not off, this point is important, as you don't want the electronics of the DC to DC charger using energy when the boat is idle. I used a Balmar DC to DC charger, which has a slight issue of introducing noise in electrical circuits which require circle magnet things and one of the wires being 10 foot long, to defeat. I would instead recommend the newer Victron product if it has the same ability to be rigged to the on/off starter switch. Like the Victron Energy Orion-Tr Smart 12/12-Volt 18 or 30 Amp.
(3) Having batteries of multiple chemistries can create additional issues, doing the above you can still have your starter battery and firefly be different chemistries.
(4) These new batteries (firefly and odyssey) have a lower resistance, which means a short will greatly increase the amount of current released. Older-style fuses won't stop this current rush, it will jump right over, so add a T-fuse to each battery that you upgrade to Firefly (or Odyssey)
(5) In 2 above you added an extra wire between the switches and the engine compartment. If you are willing to dedicate an on/off switch to the starter battery, you can repurpose your 1-2-B-Off switch for more flexibility per this article by Rod Collins https://marinehowto.com/1-2-both-batter ... derations/
(6) I found that the battery wires were undersized from the battery to the battery switches. Upgrading the wire one size can reduce voltage drops. Considering the short run, the weight addition is reasonable. Getting 45 degree battery lug made the install easier for me to route the wires and keep them short.
Note 1: if your house battery fails (never happened to me, more of an issue with Lithium batteries), have a plan like a ready-made jumper so you can get your alternator output connected to your house battery directly if your DC to DC charger is just a couple of amps. Otherwise all your alternator output will be trickling too slow if your running your house loads on your starter battery. I suppose if you have the 18 or 30 Amp Victron, that won't be an issue.
I am looking to convert to Lithium batteries. Why are they not class legal? If it's due to weight can't we just add a small sandbag or other weight to the battery compartment to account for the deficit? Or as was said above if you rewire the boat to accommodate a proper lithium setup there is no real weight advantage so why not allow that?
As one of the few people who cruise more than races, the additional capacity and faster charge times are very attractive. PKYS has drawn up an excellent system using one AGM start battery (G24 AGM at 25.5 kg) plus a single 200 ah lithium house battery (at 22 kg) with a standalone BMS and a smart battery protect/disconnect.
If installed will I not be allowed to race at BIRW this year? Can't I just add the 3.5 kg or 7.7 lb difference in battery weight to make me compliant? If I'm at the class weight carried in the correct location there is no performance advantage, it does not seem fair to not let me compete if that's the case.
Thank you.
PS I was an early adopter of the Firefly batteries. They worked great for the first season but capacity quickly fell off after that. After three years Lifelines held their capacity better than the Fireflys. YMMV
Thank you.
I just installed a Lifeline Group 31 AGM as a replacement for my previous North Star AGM. No changes needed for the charging system setup as this is basically the same. I'll report how battery life and charge / discharge times are later this season.
See my comments below - Dan Corcoran
--> Ans: It started as a weight concern and maybe some weights to fix this, but as owners with electrical and fire experience started talking, it lead to the text at the top of this thread, e.g. concern = safety x 10
--> I agree, in fact, we are working towards what the definition of "rewire" is and a reference design that achieves it.
--> Be happy to take a look at this. There is more to this on a 109, perhaps due to the age of our boats.
--> I would be happy to speak, if my answers above are insufficient. Also be happy to accept your assistance in drafting the new class rules.
Thank you.
--> The Firefly in IMHO brought a fire risk in that the battery has low resistance / ability to transmit much more current then standard lead acid starting a fire at the battery switch for example, as it could overwhelm the electrical protection features of our boats.
Thank you.
Dan - if you can register for BIRW this year you can race! :-0 ... this is the off year.
The Technical Committee will be reviewing the Lithium Battery dilemma further.
