J109 Airmar DST810 Speedo Calibration
Posted: Wed Jun 11, 2025 6:43 pm
Here's what I've come up with. I'm hoping that others will post their calibrations, so we can compare notes. Very little J/109 on J/109 racing going on here in San Francisco, so no rivalries to protect!
I aim for boat speed to be correct within |0.1| knots at >= 3.0 knots boat speed. Transducer is mounted starboard side, in what I think is the original opening, just a few inches outboard from the spine. All calibrations in reasonably flat San Francisco Bay waters, at both near slack and with a current running and corrections taken against SOG. Tweaks to this table were made over the last two years, always within a day or two of a bottom clean. I aim for repeated rotational position alignment with a marked stick, so the arrow is pointing to within a few millimeters of the same spot each time. Paddlewheel is stored in fresh water between sessions -- I find dry storing the wheel causes many tens of minutes of slowness. I want to leave the dock, verify the numbers immediately, then go racing. I start each calibration session with a number of reciprocal motor runs at 0 degree heel in a quiet, mostly slack, channel, verify those numbers, then go sailing to induce heel.
Numbers seem pretty good when eyeballing against SOG, to within 0.1 to maybe 0.2 knots, between 3 and 8 knots boat speed, up to about 25 degrees of heel, but seem OK enough at 30 degrees too. Heeled 1.5 knot numbers are just guesses.
Note the Airmar system has some common floating point representational issues. Put in 0.9, get 0.89 back.
Code: Select all
kn,0.0,1.5,3.0,4.0,5.0,6.5,7.5,9.0
20.0°P,0.00,0.60,0.80,0.99,1.11,1.30,1.40,1.59
10.0°P,0.00,0.60,0.70,0.89,0.99,1.11,1.21,1.30
0,0.00,0.51,0.60,0.80,0.80,0.89,0.99,1.11
10.0°S,0.00,0.51,0.51,0.70,0.70,0.70,0.89,1.11
20.0°S,0.00,0.41,0.41,0.60,0.60,0.51,0.70,0.89
