Replacement fuel gauge?
johnarens
Post by johnarens »
Has anyone had to replace their fuel gauge? The sender is functioning properly but my gauge always reads full. Any insights? A link to the replacement gauge?
Thanks in advance.
John
carlbraden
Re: Replacement fuel gauge?
Post by carlbraden »
G'day - yes my #148 has the same problem - my limited exploration points to the wiring not the gauge - but I am happy to hear what others advise.
When I had similar symptoms I found a loose connection on the contacts where the harness attached to the fuel gauge located on the top of the tank and that fixed the problem.
I would measure the voltage at the engine panel fuel gauge connection. There should be 3 wires including +12V, Ground, and the sending unit.
