Mid mast light
IanM
Mid mast light
Post by IanM »
The light half way up my mast is not working. Does anyone know what part I should replace it with? Trying to avoid two trips in the bosuns chair.
Thank you very much
TSweather
Re: Mid mast light
Post by TSweather »
Depending on your build date this is likely the model of your steaming light.
https://j109.org/docs/perko_steaming_li ... lation.pdf
Removing it in a bosuns chair/harness is possible, though it falls apart easily, so be sure to hold on tight as I lost a screw on the first try.
After the screw made the splash, I found that cleaning contacts and replacing the bulb was not enough and that I have some other issue with the circuit. Hope yours is easier to solve.
Todd
#41
IanM
Re: Mid mast light
Post by IanM »
Many thanks. Will let you know how it goes.
IanM
Re: Mid mast light
Post by IanM »
On the plus side this is the exact same model that needed replacing with the only slight difference being the screw size for the base plate attachment to the mast: the new model is smaller so the holes in the plate need to be drilled out a bit.
On the minus side, like you, this does not seem to be the issue as neither the new nor the old lights are working…
