Outhaul boom cleat replacement
My under-boom aluminum outhaul clam cleat, probably original, has been slipping for a while now. Any advice from someone who has successfully upgraded to a solution with a little more positive control? Perhaps a small cam cleat with a fairlead to keep the line captive? Or is it best to stick with the original clam cleat setup? Given all the in-boom purchase, I can't imagine that the SWL needs to be more than 200 or so pounds.
Re: Outhaul boom cleat replacement,
Mine wore out as well. Instead of replacing the clam cleat (that slips any way) I used the Ronstan dingy pivoting Lead block w/ small T-cleat (cam-cleat) http://www.apsltd.com/pivoting-lead-blo ... cleat.html
I took the lead guide off the cam cleat then tapped 2 screws about 6-8 inches aft of the current pulley, then mounted it under the boom. So the outhaul leads aft through the lead block then through the cam cleat. So far it is working even under heavy loads. I haven’t removed my old clamcleat or pulley yet, until I see if this dingy cleat will hold up. It outhaul line is at the maximum size. Harken and Ronstan do make a larger system if this fails, I just don’t know if the base will fit inside the groove on the underside of the boom. Right now I sail PHRF so I don’t know if this modification is OD legal.
- 3CE185EE-ABD8-4A88-AC88-D03255AD87EB.jpeg (1.15 MiB) Viewed 15963 times
Interesting. I initially assumed that something like this would be possible. But then, looking at various catalogs, I didn't see an obvious solution for mounting a relatively wide cam cleat into the very narrow channel under the boom.
A photo of how you mounted the cam cleat to the underside of the boom would certainly clarify things, if you happen to have one.
This may help. I can get a picture this week after Wednesday racing.
My outhaul cleat wore out last season too. Looking for the easiest way out I replaced it with the exact same part. It was cheap and took less than ten minutes to install. The line has not slipped once since. Probably the easiest boat repair ever. Guess you can put something better but been out in mid twenties and no slipping so seems good to me. YMMV
BTW if you compare the old cleat to the new one you’ll see how the line just wears through the soft Al. The new one works perfectly.
I also replaced my out haul cleat last year. Mine is attached to the base of the mast and the pull is straight up. I just never liked the idea of people pulling the line back or to the side. I could see at some point that line breaks and someone goes swimming.
