The light half way up my mast is not working. Does anyone know what part I should replace it with? Trying to avoid two trips in the bosuns chair.
Thank you very much
Mid mast light
Re: Mid mast light
Depending on your build date this is likely the model of your steaming light.
https://j109.org/docs/perko_steaming_li ... lation.pdf
Removing it in a bosuns chair/harness is possible, though it falls apart easily, so be sure to hold on tight as I lost a screw on the first try.
After the screw made the splash, I found that cleaning contacts and replacing the bulb was not enough and that I have some other issue with the circuit. Hope yours is easier to solve.
Todd
#41
Todd
#41
