Table Pieces Help Please
Will1552
Post by Will1552 »
Good morning fellow sailors. I need some help. I am missing the two pieces for the top of my table and wonder is someone could measure and send me some photos and measurements so I can reproduce them. The middle piece for the bottle/liquor storage is easy, what I really need is photos and measurements of the separate piece that goes around the mast at the front top of the table and how it is built. Would any of you be able to help me out?
I attached a photo to help show what I am looking for.
Merry Christmas to all of you, I hope Santa brings you cool stuff for your boats.
j109 table piece.PNG (809.4 KiB) Viewed 16441 times
Will1552
Re: Table Pieces Help Please
Post by Will1552 »
Sorry for the second note. My boat is a USA Built boat.
Phoenix251
Post by Phoenix251 »
Got you covered. I will be heading to boat today and will post photos/measurements tonight. Standby.
Will1552
Post by Will1552 »
Thank you!! I appreciate your help. I am missing both pieces, the liquour box top as well if you remember, if not, that one is easier to guess on ha
Chris
USA 359
Phoenix251
Ok, got it. It will be hard to make sense of the measurements from just the pictures, but you should be able to match things up with the more exact measurements. They are 15 1/2, 12 3/4, 9 3/16, 4 1/4, 8 3/4, 7 3/4, and 7. Standby for center insert.
Best
Matt
Phoenix 251
Phoenix251
Photos part 2 - forgot to measure height and height of the forward lip/trim piece, but photo attached. Trim piece is probably an inch.
Top
Top
Will1552
Post by Will1552 »
Wow, great photos and measurements. This will help a lot! thanks Matt.
Chris
BombShell USA 359
Phoenix251
My center insert is a bit “modified” and original is in storage, but dimension are the same. L 20 3/4, W 4 3/16, H is about 3/4.
Probably best to assume that all tables have small differences, but this should get you close. Have fun building!
BTW, there is a prior post on varnish. Epifanes Rubbed Effect is a good match.
Will1552
Post by Will1552 »
Matt Thanks Again for the great photos. I also like the tip on Epithanes and have some coming.
Will1552
Post by Will1552 »
Matt, circling back as I am finishing these now before lauch comes in 5-6 weeks....
Did you convert your liquor top to a bottle holder or can holder?
Chris
Phoenix251
Hi Chris,
Converted for cans. I have the original in storage. Can get a photo of original if needed. I have found that mounting a shoe/storage holder on the mast with zip ties works really well for a Nalgene holder (for Macs).
https://a.co/d/5jh90hm
Matt
