110 Volt Circuit Breaker Replacement
Frank Albert
Post by Frank Albert »
I'm having a problem with the outlet circuit breaker. It trips pretty eash and at way less than it's rated amount of 10 amps. Has anyone replaced any of their circuit breakers?
Re: 110 Volt Circuit Breaker Replacement
I had a similar problem and swapped the 10amp breaker with a spare 15 amp breaker that wasn't being used. It fixed the problem.
