Clear Engine Ignition Cover Replacement / Repair
The swinging cover over the ignition key broke at the little nub the screw goes into.
Anyone have any luck repairing (5200?) or replacing it?
Strider
jng7000
Re: Clear Engine Ignition Cover Replacement / Repair
Post by jng7000 »
The company that supplied those covers is out of business last I heard. Might be able to find some type of plastic fabricator locally to make a new one or just go to Home Depot and pick up a piece of plexiglass and make a new one. Alternatively you could you grind off the nub and maybe put a hinge on the top? I've thought about doing that to mine thinking it may work better.
Jim
"Junkyard Dog" #168
I purchase some clear Lexan at Home Depot and traced the old one using a scroll saw, then carefully drilled the holes. I masked the edge on the backside and painted the outer edge black, then put on foam with adhesive along the edge. It works great.
Great Ideas, Thanks!
I finally pulled the trigger on this replacement. The Plastic Factory in Bridgeport, CT made it. I chose the tint. Very reasonably priced and great customer service. https://www.theplasticfactoryct.co
Bill's recommendation on painting the outside edge (1/2 inch all around) was great. Much better result than the black vinyl tape used by the factory.
Before and after pics below.
Finished Panel.JPG (34.44 KiB) Viewed 13364 times
Old Panel.JPG (50.88 KiB) Viewed 13375 times
John,
Do they have the dimensions to produce this for a "standard" order, or was it a one time custom build?
It was a one-off using my old one as a template. I am happy to give the old one back to them as the mold if this is something we think is worth doing.
Producing More? I would like one!
