I have an 83mm wide fiberglass hole tabbed to the inside of my J 109, for a radar pole. The previous owner had a custom carbon fiber radar pole here.
Is the hole standard? Where to find a similiar size radar pole, aluminum or carbon fiber? Most poles seem to be 3" wide and would be too small, yes?
Strider #332
Radar Pole Question
Re: Radar Pole Question
I believe Vento Solare uses a 2-3/8" diameter pole. You can always insert a sleeve and use a smaller diameter. Math says 83mm is 3.268" diameter.
