2014 UK tape drive class jib, Load Path Tape, Carbon Tapes and Technora Base Cloth, 3 Vertical Battens, Pocket Velcro Closure, AP Construction, w/Tag (1402587K verified). Sail maker gave a rating of 4.5/5 when they evaluated sails that came with the boat in May 2017, it then got an additional 20 hrs of use in 2017.
The jib is intended to be paired with a light weight jib, this one being used for the heavy wind ranges and used less often.
$1,100
Sold: OD 105% Jib for sale
Re: OD 105% Jib for sale
Hi, very interested.. could you send a photo and where are you located. Easiest way to contact text or call 917/747-5132 or email lawlerjohn@msn.com. This john
