Coolant issues
I found my coolant leaking at the hot water heater connections as well. It turns out the fittings that connect the coolant hose from the engine to the hot water heater and back to the engine were made of low temperature plastic, and not the right material for the high temps of the coolant going to the heat exchanger. I have asked Pearson Composites to send metal (?brass) fittings as shown in their photos in the technical bulletin. These low temp fittings could be a major problem, mine were very close to failing when I discovered the problem. If the fittings fail, all the engine coolant would quickly drain in to the bilge and quickly overheat the engine.
[Posted by: Sam Mitchener
