Interfacing Yanmar 3YM30 to NMEA-2000
Post by Dan Corcoran » Sun Aug 25, 2019 11:48 am
Interfacing Yanmar 3YM30 to NMEA-2000 for purposes of having engine information appear on chartplotter.
Has anyone done this yet? What is involved?
What values do our 3YM30's output?
Thanks!
Re: Interfacing Yanmar 3YM30 to NMEA-2000
Post by Vento Solare » Sun Aug 25, 2019 12:00 pm
There are no N2K sensors on a 3YM30 unless you spend significant $ to do it yourself.
Post by Vento Solare » Mon Sep 02, 2019 7:57 am
PS - here are some N2K data converters for the YM series engines. Some may require additional sensors. This is not an inexpensive solution to display the engine data on a NMEA 2000 device.
Post by Dan Corcoran » Mon Sep 02, 2019 5:20 pm
Wow, so expensive.
Has anyone founds a solution to the Tach sometimes maxing out?
Post by Vento Solare » Tue Sep 03, 2019 9:05 pm
Most likely a loose connection probably on the alternator. The tach is driven from the alternator and counts pulses which are proportional to engine speed. See this link to calibrate it. viewtopic.php?f=4&t=1008&p=776&hilit=tach#p776
