2005 J/109 Ursa, Hull #203 - Located Fall River, MA
US$135,000
Photos can be found at https://www.yachtworld.com/yacht/2005-j ... -10235021/
Please contact Tim Kohl at 203-233-9709
Sail Inventory
Racing Sails
• 2017 North 3Di mainsail
• 2014 North 3DL mainsail
• 2016 North 3Di 105% jib
• 2015 North 3DL 105% jib
• 2024 Quantum spinnaker (blue)
• 2018 North spinnaker (white)
• 2012 Quantum spinnaker (red/white/blue)
• Code 0 with furler
Cruising Sails
• UK Sailmakers mainsail with Dutchman system with additional mainsail cover
Engine
• Yanmar 3YM30 diesel engine (29 HP)
• Yanmar SD20 saildrive
• Heat exchanger removed, cleaned, serviced, and reinstalled as well as overall engine serviced (2024)
• Saildrive serviced and inspected regularly
• No signs of water intrusion noted during 2025 saildrive inspection
• Saildrive zincs replaced annually
• Alternator belt replaced (2026)
• Total engine hours unknown due to replacement of the engine-hour meter. Approximately 1,300 hours since 2010. Engine has been professionally maintained and is in regular use.
Electronics
• B&G Zeus³ 7" GPS/Radar display at helm (2022)
• B&G Triton2 S/D/W Wired Wind Package with 2 Displays and B&G Vulcan 5" on spray hood
• 2020 B&G radar
• Raymarine GPS/radar at navigation station
• Raymarine ST6001 autopilot
• AIS (receive and send)
• Icom VHF radio
• Tacktick - mast mounted
• Removable speed wheel with blanking plug
Electrical
• 12V DC electrical system
• 120V AC shore power
• Three Odyssey ODX-AGM31M AGM batteries (2024)
• Victron BMV-712 battery monitor (2024)
• New Balmar MC-618 regulator and Balmar SG-200 battery monitoring system installed (2023)
• Xantrex PROwatt SW 1000 Power Inverter (2020)
• Upgraded alternator
• New battery charger (2026)
• New SmartPlug shore power cord (2026)
Equipment Included
• Custom Fairclough winter cover
• Dodger
• Removable dock box
• Tides Marine SailTrack system
• Wheel and mainsail cover
• Anchor roller
• EPIRB
• LifeSling and horseshoe buoy
• Fenders and dock line
Maintenance & Upgrades
Rigging / Deck
• S1 and S2 spreader bars upgraded, and rod rigging components serviced by Newport Rigging Group (2025)
• Standing rigging replaced (2011)
• 2019 epoxy isolation of all deck hardware penetrations including chainplates and stanchion bases (pictures can be provided)
• New lifelines (2024)
• New sheaves in mast replaced (2024)
• New sheaves in boom replaced (2020)
Running Rigging
• New spinnaker halyard (2026)
• New main halyard (2023)
• New jib halyard and jib sheets (2022)
Hull / Steering
• No known wet-core issues
• 2024 upper and lower rudder bearings replaced
• 2024 bottom professionally stripped/prepped and converted to SeaHawk BioCop TF
• 2026 fresh bottom paint (2 coats
Mechanical / Plumbing
• Bilge system serviced with new Rule 1100 GPH bilge pump and Ultra Safety float switch (2019)
• Two new Plastimo 39-gallon flexible water tanks (2020)
• Head hoses and joker valve replaced (2022)
Safety
Two new Amerex fire extinguishers (2023)
For Sale: Ursa, Hull #203 - Located Fall River, MA
