Removable pipe cots
Frank Albert
Re: Removable pipe cots
I've installed my first one on the port side. I made some wood sleeves for the pipes to slide in to and through bolted them at the sink and near the cupboard in the galley. Also through bolted them in the forward port hanging locker an in the V-birth area. I made the wood sleeves out of two by fours and cut out a grove that the pipes would slip into. I bought a stretcher on line and took it apart. Had to cut the pipes to fit and had my sail maker provide a Dacron berth with sleeves to slide the pipes in. The 2X4s are there when the berth is in and when it's not up and being used the wood is taken down and replaced with bolts and acorn nuts. I plan on making another one for the starboard side this winter. It doesn’t look bad at all and I'll be able to sleep two more people in the cabin. If you want some pictures let me know.
Frank,
I would like to see pictures of the pipe berths if you have them handy.
Thanks.
Thanks.
I don't have any pictures right now but I'll take some early this spring. I might need an email address to send you the pictures. Not sure I can post pictures on the board.
Frank
Frank
Frank - here are directions for posting pictures on the forum: http://www.j109.org/forum/viewtopic.php?f=1&t=11
