Steering System maintenance
bmastror
Post by bmastror »
Just went through a 10 year inspection of my steering system and thought I would share a few highlights. Edson Marine was a great help in supporting this!
Removing the old cable and chain (they are connected):
All access panels on pedestal must be removed (including compass on top)
On top of radial wheel - use an 8mm open ended fixed wrench
Remove 2 cable holders off each cable (2 nuts on each holder at tip of U bolt)
12mm open ended fixed wrench - loosen and remove 2 nuts off ends of 2 threaded eye bolts
Put straight tool tip in eye to prevent rotation
Remove cable and threaded eye bolts from radial wheel
These all get replaced and are included in the chain/wire/cable kit
Tape tracer lines (about 5-6 feet long) to end of cables
Pull chain and wires out through top of pedestal. Have someone down below to help tread up wires.
Secure both ends of tracer lines
Remove split pin and center bolt from 2 sheaves and check needle bearings. If needle bearings are falling out, replace (this was the case with mine). If good, clean and lube with Teflon lube.
Reverse everything to get new cable and chain in place - note cables do cross in pedestal. Make sure they are crossed without interfering.
I have pictures, but they were too large to load - will see if I can get the posted later.
bmastror
Re: Steering System maintenance
Post by bmastror »
Some Pictures
Cable holders_s.jpg (32.75 KiB) Viewed 8926 times
threaded eye bolt_s.jpg (30.74 KiB) Viewed 8926 times
chain and cable kit.jpg (38.25 KiB) Viewed 8926 times
bmastror
Post by bmastror »
Final pics
tracer lines thru sheave holders_s.jpg (47 KiB) Viewed 8926 times
sheave with center bolt and split pin_s.jpg (32.94 KiB) Viewed 8926 times
