How to replace Delrin pole control line fitting?
J-109 Emoticon
Post by J-109 Emoticon »
Anyone ever replace the Delrin fitting for the sprit control line? I have the fitting, only comes in black now unfortunately however unsure how the old worn one is removed and replaced. Any thoughts are appreciated.
Re: How to replace Delrin pole control line fitting?
If you are talking about the Delrin fitting where the line exits the aft bulkhead on the cabin, it is just a friction fit. Grab it with pliers, twist and pull out. You might want to check with Waterline Systems to see if they have it in white. Call Ted Slee 401 247 3000 x319
J-109 Emoticon
Thanks Bill,
I'll give it a try, didn't want to risk forcing the fitting out and doing damage. Waterline was my first call, they only make the fitting in black now, oh well.
JR - Try measuring the ID and OD, then get something like a plastic mushroom thru-hull that is made from white Delrin. You can saw off the hose barb.
I found the white delrin thru deck fairlead today at the Ship's Store consignment shop in Portsmouth, RI. The part number is Schaefer 76-05 and they have 6 on the wall (on 5/17/2016).
If anyone needs one, let me know and I can pick it up and mail it to you. Cost is $7 plus tax and shipping.
