We developed a backstay leak. Does anyone know which rebuild kit works on this backstay? Says is custom for 109.
Thank you.
Backstay rebuild
Re: Backstay rebuild
These two Sailtec documents are posted on the J/109 site under "Info", "Drawings & Manuals". It is J/109 Custom based on the -10 size with the Sailtec part number -10CUSTOM (J-109).
- Sailtec Backstay Adjuster Oil Drain and Fill Procedure - 10/2/2008
- Sailtec Hydraulic Backstay Adjuster - Service Maintenance and Repair Manual - 1/15/2015
- 42000 Integral Pump
- 42010 -10 Cylinder
Have you checked a marine supply store?
