Table and Door hardware help
Will1552
Post by Will1552 »
Good afternoon gang. I know most of you remove your table and doors to make racing easier. I on the other hand am putting the table and doors back in. However, there is no hardware that I can find in the boat or with the stuff that came with the boat. I am hoping this group can help me out.
What is the size of bolts, nuts and washers that attach the table to the floor?
What and where can I buy Hinge pins for the doors? Does anyone have parts #?
Any help that you can give is appreciated.
Chris
Re: Table and Door hardware help
Hi Chris,
I was down at the boat today and took a couple photos of the cabin door hardware. The door handles resemble the ones made by Perko, though there are no markings on this part and instead of a knob on one side these have levers on both sides. They are slightly recessed into the surface. The hinges are 2" chrome basic cabinet hinges.
As for the table, those are likely either M8 or 5/16-18 coarse threaded with countersunk heads. I don't have the length since my table is still installed and I have never removed them.
Todd
#41
Will1552
Post by Will1552 »
Thanks Todd, that is great info and very helpful! The hinge is Perko, hard to find the 6 hole version but they sell a 4 holes version with a removeable pin which solved my problem. The table hardware I will pick up with your suggestion this week.
Does anyone know a source for the cabinet door hinges around the J/109, like those found in cabinet just inside the forward birth?
Does anyone know a source for the water spigets?
