I’m commissioning a new B&G NAC-3 autopilot on “Justified” (Erie PA) using a Vulcan 9R, Precision-9 compass, and RF25N NMEA 2000 rudder feedback sensor.
The only issue preventing commissioning is the RF25N. During rudder calibration, the displayed angle doesn’t change smoothly with wheel movement. It sits at one value, then jumps several degrees, often showing nonsensical numbers (for example, around 62° with the rudder centered). Calibration cannot be completed.
To rule out installation issues, I removed the RF25N from the boat and rotated it by hand. It exhibits the exact same erratic behavior, so it doesn’t appear to be caused by linkage geometry or mechanical installation.
The NMEA 2000 network diagnostics show no dropped frames or communication errors, and the RF25N is the only device on the network providing rudder angle data.
Has anyone seen an RF25N behave this way? Was it ultimately a defective sensor, a firmware/configuration issue, or something else I should be checking before I replace it?
NAC-3 Autopilot and RF25N Rudder Sensor
Russ Thompson
Hull 240
Erie PA
Hull 240
Erie PA
Re: NAC-3 Autopilot and RF25N Rudder Sensor
Sounds like a defective sensor. I've done multiple installs and never seen a problem like this. Your offline test seems to confirm the sensor output is bad.
The sensor was bad and it has been replaced.
Russ Thompson
Hull 240
Erie PA
Hull 240
Erie PA
