I have just discovered a leak in the saloon ceiling, port side, draining down the wooden bulkhead over the stove. Origin not apparent-- any experience oput there? hull #286
[Posted by: David Frizell
Leak in saloon ceiling
One possiblility... For units with refrigeration, you may experience condensation of the refrigeration lines on the port side aft of the ice box. The lines run from the ice box to the cooling unit located in the back of the lazarette (approx under the wheel). The factory doesn't really insulate these lines and only puts them in this flexible plastic tube with a slit running through the middle of it. It looks like a wire organizer... Anyway, condensation and/or ice forms on the refrigeration lines inside this wire organizer which runs though the galley cupboards and behind the headliner in the aft berth... Colder ice box settings seem to make this problem worse... If your leak mysterious disappears when you have not been using refrigeration unit for awhile, this may be your problem... Unfortunately, I'm not aware of a solution...
Aventura - # 263
[Posted by: Pete Corpstein
Aventura - # 263
